Activity Forums Apple Final Cut Pro Legacy capture settings
  • capture settings
    Posted by Matt Walker on August 11, 2010 at 5:47 am
    I have 25 full 63min mini DV tapes to capture for a client.
    What would be the best capture settings and codec to use for;
    1. DV
    2. HDV
    Capturing using Sony Deck & using FCP 7
    I would like to keep file sizes to a minimum and the end product doesn’t need to be HDV but im just curious of the file sizes ill get from the two different formats.
    Cheers Matt
    Rafael Amador replied 16 years ago 3 Members · 4 Replies
  • Rafael Amador
    August 11, 2010 at 6:26 am
    [Matt Walker] “What would be the best capture settings and codec to use for;
    1. DV
    2. HDV”
    If you are capturing through FW, you capture the original codec.
    To capture as HDV you would need to resize and transcode on the fly.
    [Matt Walker] “I would like to keep file sizes to a minimum and the end product doesn’t need to be HDV but im just curious of the file sizes ill get from the two different formats.”
    Same size. DV and HDV have the same data rate: 25 Mbps.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • David Roth weiss
    August 11, 2010 at 9:05 am
    Both DVand HDV occupy 13gb storage per hour tape.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Matt Walker
    August 12, 2010 at 1:51 am
    I seem to be getting 43gb for an hour tape using HDV-Apple ProRess 422
    I would be happy with 13gb
  • Rafael Amador
    August 12, 2010 at 11:23 am
    As David wrote, any of both formats (DV, HDV) take 13GBs per hour.
    rafael
