Activity Forums Apple Final Cut Pro Legacy Capture setting for HDV to DV iLink converter
  • Capture setting for HDV to DV iLink converter
    Posted by Bram Vergeer on October 3, 2008 at 2:03 pm
    Hello,
    I use the Sony HDR-HC1e PAL camera. I film in HD and I use the iLink converter to capture the material in DV format in FCP. I can’t figure out how to put the capture setting to capture the material in DV 16:9 (the original format since HD is always 16:9)
    Thanx bram
    Bram Vergeer replied 17 years, 11 months ago 2 Members · 2 Replies
  • Jerry Alto
    October 3, 2008 at 6:09 pm
    Bram- That be the anamorphic button in the browser, Bram.
    HTH,
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
  • Bram Vergeer
    October 7, 2008 at 9:39 pm
    Thnanx Jerry,
    I put the capture settings on anamorphic and the sequence settings normal dv pal. That works
    Now the editting. My viewer window in FCP has the image in 16:9. My Canvas window (of the sequence) has the image also in 16:9 but with the black bars. I want to export the film eventually as 4:3 but full screen, so without the bars. That means a part on the left and a part right side will fall off. In this situation I have to rescale every single file I edit individually by enlarging the wireframe. That of course is a lot of work. Is there a more easy way out??
    Many thanx again!
    Bram
