Activity Forums VEGAS Pro capture question
  • capture question
    Posted by Jonathan Bach on February 24, 2010 at 6:37 pm
    I just captured my first dv footage on Vegas 9 and it dropped 501 frames in 60 minutes of footage. I am capturing from a dvx100b thru the 1394 ohci compliant host controller jack on the motherboard of a Dell studio xps 8000 2.8g i7 machine; do I need to install a seperate IEEE 1394 capture card?
    John Rofrano replied 16 years, 6 months ago 3 Members · 3 Replies
  • John Rofrano
    February 24, 2010 at 7:10 pm
    Were you capturing to a separate hard drive or the same hard drive that Windows is on (i.e., C:)? Do you have a permanent swap file set up? 501 is a lot of frames to be dropping but I would be sure that the rest of your system is set up correctly before you buy another firewire card. I capture with the firewire built into my motherboard all the time and I never get dropped frames.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeremy Rasnic
    February 24, 2010 at 9:00 pm
    Also, just for troubleshooting, try disabling any antivirus during the capture. You may also want to ensure that you don’t have a bunch of background programs running that are not needed. (you can disable them by going to start/run/ and type in msconfig. There should be a tab called startup. You can uncheck everything that you don’t want running (or don’t need running).
    j razz
    https://www.jrazzcreations.com
  • John Rofrano
    February 25, 2010 at 12:58 am
    …and depending on which OS you are using, check the Device Manager to see if the firewire device is also being used as a network adapter. If it is, disable that network adapter. This particularly important to check on XP.
    ~jr
