Activity Forums Apple Final Cut Pro Legacy Capture Question: 1080i60 vs. 1080pA24
  • Capture Question: 1080i60 vs. 1080pA24
    Posted by Elizabeth Czyzewski on March 10, 2008 at 7:04 am
    I’m about to start capturing footage and I just wanted to check on the best capture setting to use. The DP sent me this information:
    The footage was shot at 24p but recorded in camera as 1080i with 3:2
    pulldown. I would advise removing the 3:2 pulldown prior to
    cutting. You will then have 24p footage to work with. Format was
    Panasonic DVCPro HD.
    I wasn’t sure if I should capture at 1080i60 and enable the “remove advanced pulldown” option (this was suggested by someone I mentioned this to) or capture at 1080pA24, which already has the “remove advanced pulldown” option enabled?
    Thanks.
    Chris Borjis replied 18 years, 6 months ago 2 Members · 1 Reply
  • Chris Borjis
    March 10, 2008 at 4:30 pm
    I believe you want to capture it 60i and use the pulldown tool after the fact.
    do a short test clip to confirm that, but thats how its usually done.
