Activity › Forums › Apple Final Cut Pro Legacy › Capture Problems, yet again.
  • Capture Problems, yet again.
    Posted by Slfilms on July 18, 2006 at 8:25 pm
    Hi guys. I’m doing a music special with five cameras, all synced with the same TC. Some of the backstage was shot with a DVX 100B. Over the weekend I experienced a huge problem when in the Log and Capture function. I tried to bring in anamorphic XDCAM via SDI through my Kona LS but everything that was captured was squeezed into 4×3 frame. That issue was resolved by upgrading from 5.0 to 5.1 (I then upgraded to 5.1.1. Thank you Walter and Jeremy and Rob at Advanced Systems Group in Oakland, CA
    Now when I try to capture, both from my XDCAM deck via SDI and with my Pana DVX 100B via firewire, I get a prompt that there is a timecode break and FCP stops capturing. There is no break in timecode and the problem is random, never in the same place. I can only capture about three minutes before FCP punks out.
    I read the post about user prefs and deselected Abort Capture on dropped frames / On time code break. I think I then chose “Warn After Capture” This worked and I’m able to capture what I want, but at the end of the capture I get the “you had a timecode break. Relog and recapture” warning. This appears to be a FCP issue. Since I’m experiencing the same problem with both SDI and Firewire DV I believe that eliminates the AJA LS, the XDCAM 1500 deck and my DVX as hardware problems. The situation scares me as I’m offlining in DV and will export/import an edit list and recapture in DV50 Anamorphic.
    Any suggestions as to the cause and solution to the phantom “timecode break” prompt?
    Ashley James
    Jerry Hofmann replied 20 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 19, 2006 at 2:58 am
    Might clone the tape, if the timecode isn’t recorded with a very solid signal, FCP will report it’s broken. We had a camera that was dirty, and had this problem, cleaned the camera and it fixed the problem. Cloning the tape to a machine that records hotter tc may fix you up now.
    Jerry
