Activity Forums Apple Final Cut Pro Legacy Capture Problems in FCP 4.0
  • Capture Problems in FCP 4.0
    Posted by Jared Medeiros on November 6, 2005 at 4:49 pm
    Hi all,
    I was attempting to capture some footage in FCP 4.0 and ran into a few problems. When I opened FCP it would not recognize my camera (Canon ZR200). After confirming the proper device setting in my preferences were correct, I opened the Log and Capture window and FCP would repeatedly crash.
    I tried again, this time using another camera (Panasonic DVX100A) and had the same results: FCP crashes when attempting to Capture.
    I switched FireWire ports and tested both cameras and cables in iMovie and everything worked just fine.
    I Trashed the preferences and had the same results. I then attempted to completely unistall and reinstall FCP. After the reinstall the problem continued. But I know that I didn’t completely unistall the previous version because I did not need to enter my serial #.
    I ran a search for “Final Cut” and deleted all folders and files associated with the program and attempted to reinstall again. Again, the same results: the serial 3 is still there and FCP crashes upon attempting to open the Capture window.
    Can someone please help me COMPLETELY remove Final Cut Pro 4.0 from my system so I can start from scratch with a totally fresh install? I followed the unistallation instrustions on Apple’s site but there must be a preference or config file somewhere that I’m missing.
    If anyone can help with the installation or simply have a suggestion for fixing the “crashing when attempting to capture” issue, it would be much appreciated.
    Thanks a lot!
    Jared
    Gunleik Groven replied 20 years, 9 months ago 3 Members · 3 Replies
  • Joseph Bradley
    November 6, 2005 at 5:02 pm
    First question. After the re-install does FCP recognize the camera? And is the camera turned on before starting FCP? So, it was two questions.
  • Jared Medeiros
    November 7, 2005 at 1:16 am
    No, after the reinstall the problem persists. FCP will not recognize the camera and will crash upon opening the Log and Capture window.
    And yes, the camera is powered on.
    I guess I’m just looking to do a complete reinstall without any left-over files or folders.
    Thanks for the response. Any additional help would be much appreciated.
    Jared
  • Gunleik Groven
    November 7, 2005 at 10:15 am
    Have you tried upgrading to 4.5?
    The upgrades solved a lot of weird bugs.
    Gunleik
