Activity › Forums › VEGAS Pro › Capture problems from dvcpro deck with vegas 6
  • Capture problems from dvcpro deck with vegas 6
    Posted by Dave Talko on December 3, 2005 at 9:40 pm
    I am trying to capture from a Panasonic aj-sd93 deck with vegas 6 through the ieee1394 conection. I am told that the deck should be plug & play and the computer does detect it but when I get to the capture interface it says the device is busy or being used by another program. Any thoughts on a possible fix. Is DVCpro50 an unsupported format or codec??
    thedave
    Dave Talko replied 20 years, 10 months ago 3 Members · 3 Replies
  • Sada
    December 3, 2005 at 10:44 pm
    You will need a codec for DVPRO50—–Matrox makes one. Go here, fill out the registration form and download the codec. https://www.matrox.com/video/support/ds/software/codec/home.cfm
  • Donatello
    December 4, 2005 at 5:21 am
    you can also download the mainconcept DVCpro50 codec to try out
    https://www.mainconcept.com/codecs.shtml#dvcpro
    i’m not so sure that will solve the deck capture .. i haven’t tried any of the DVCpro decks in years but back then their deck 1394 cards were not OHCI spec’s. also back then DVCpro25 was not OHCI ( header wrapper was different).. panasonic DV product did meet OHCI spec’s …
  • Dave Talko
    December 4, 2005 at 5:25 pm
    Thanks I appreciate the links and help. I will try them out and post the results.
    Dave
    thedave
