Activity › Forums › Panasonic Cameras › capture problems!
  • capture problems!
    Posted by Zeliha Bozkurt on February 17, 2007 at 6:52 pm
    Hi
    I have logged HD-DVCPRO tapes using DVCPRO HD 720P 30. Then decided to capture them using Blackmagic HDTV 720P 59.94 8 bit.
    The problem is when I use the batch capture command it seems to find imaginary timecode breaks then split the clip into bits 🙁
    However when I check the tape there are no tc breaks and when I use capture now it captures the whole clip without any tc breaks. I also tried to bach capture and single logged clip this time it captured it as a whole clip but moved the media start and end poins as well as doubbling the clips duration. So it would capture a wrong section with the exact lenght of the original clip then captures as much black.
    This is a large project and I dont have time to capture everything one by one.
    If anyone might have an idea as to what might be causing this please reply.
    Thanks.
    Zee.
    Zeliha Bozkurt replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
