Activity Forums Apple Final Cut Pro Legacy capture problem
  • capture problem
    Posted by Gerundio on February 3, 2007 at 10:30 am
    Dear all,
    I’m recently having trouble capturing SDI 10-bit uncompressed video using the AJA Io box, Mac G5 (4 Gb ram, dual processor) on Xraid. Tried everything; updating firmware, re-installed and updated FC (i’m using version Final Cut Pro 5.2.1). The problem is freeze frames in video capture ( while audio capture continues well). I even closed any other application during capturing to avoid conflicts ( shouldn’t be neccessary should it?) The problem occurs at random, tried to capture on the intern hardisk, but doesn’t make any difference..
    Do you have any suggestions?
    Thanks for your time!
    Gerundio replied 19 years, 7 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    February 3, 2007 at 2:03 pm
    Are you running all of the latest drivers for the X Serve Raid? Their are some newish ones I think.. Is this with all tapes? and what is the source footage? Digi Beta or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gerundio
    February 5, 2007 at 8:55 am
    Hi Jerry,
    yes my source footage is Digi Beta, tried to change capture from different VTR’s but without change, using also different tapes. I’m currently using X Serve Raid driver version 1.0
    I’ve been suggested by the dealer assistence, since we’re using two workstations (same configuration, AJA IO, G5) connected to the X Serve Raid, to connect one of the G5 to the Xraid by LAN…? Since the other workstation doesn’t have any capture problems at all, it sounds to me as a strange advice? But perhaps it is needed to install xserve raid admin, so that I can upgrade the X raid driver?
  • Gerundio
    Hi Jerry,
