Activity Forums Apple Final Cut Pro Legacy Capture Now problem
  • Capture Now problem
    Posted by Harry Katz on April 13, 2009 at 9:01 pm
    I have a mini-DV tape that recorded HDV material from a Canon HV-30, but some tape at the end recorded some video from a Sony HDV camera although the tape indiciates it is DV material. When I try to capture the earlier HDV material, the Capture Now freezes after a few seconds. I’ve tried changing the Audio/Video settings from HDV to DV but nothing seems to work. Is there any way of overriding FCP so it will just capture the material?
    As a last ditch effort I captured into Adobe Premiere Pro, which I know nothing about, and it did capture the footage, but I have green screen editing to do which I can’t begin to figure out in this app.
    Dennis Radeke replied 17 years, 5 months ago 2 Members · 1 Reply
  • Dennis Radeke
    April 14, 2009 at 11:53 am
    If you’ve captured the footage in Premiere Pro you can either take it into FCP for whatever work you need to do or do it directly in Premiere Pro. Neither NLE has a terrific chroma key, but in Premiere Pro, you can send the clip(s) to After Effects where you can use the included Keylight plugin.
