Activity Forums Avid Media Composer Capture not active
  • Capture not active
    Posted by Danadana on October 15, 2007 at 10:31 pm
    Hi everyone,
    I just installed Avid Xpress Pro (4.5) on a new computer and I have a problem. The “Capture” (under “tools”) and the “Batch Capture” (under “bin”) aren’t active (grey). When I connect my Panasonic DV camera to the firewire
    Danadana replied 18 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Phillips
    October 16, 2007 at 9:53 am
    DId you set up a deck/camera in the deck settings of the application first?
    anything 24fps
  • Brendan Thompson
    October 17, 2007 at 11:47 pm
    Do you have a MOJO?
  • Danadana
    October 18, 2007 at 8:03 am
    The deck setting is Generic-DVDevice-PAL.
  • Danadana
    October 18, 2007 at 8:04 am
    I don’t have a MOJO
  • Danadana
    October 18, 2007 at 8:18 am
  • Brendan Thompson
    October 19, 2007 at 8:03 pm
    Before you try that, have you gone under either “media creation” or “capture” and checked to see that “filter based on resolution” is turned off. If you’re capturing to your main drive and “filter out start up disk is” checked you won’t dig to the c drive.
  • Danadana
    October 20, 2007 at 3:37 pm
    Well,
    I’m not capturing to the main drive. I’m capturing to D drive.
    Anyway, I tried to click Start, then Run and then type regsvr32 DVBuffers.ax (as suggested at the Avid web site) but it didn’t help. I got a massage that the file dosn’t exsist…
