Activity Forums Apple Final Cut Pro Legacy Capture Issue
  • Posted by Christine Monaco on June 10, 2009 at 4:34 pm
    Hi. I searched the forums but haven’t seen this particular problem. I’m running FCP 6.0 on a Mac Pro with dual 3 GHz processors and 4 MB of RAM. We capture over Firewire with a Sony HVR-M25U deck.
    Suddenly FCP is locking up when capturing (HDV). I have deck control, and I can see the video while logging, but when I attempt to capture the deck will cue up, play through pre-roll, and then FCP will just freeze within a few seconds of beginning the capture. The deck continues to play normally. Sometimes I get a “general error” message and sometimes I have to “ESC” out of the capture. I’ve tried trashing the prefs, but no luck. It happens whether I’m Batch Capturing or using “Capture Now.” The only other active Firewire connection is a 1 TB hard drive that we’re using for the Capture Scratch, but it’s plugged into a different bus.
    This is a brand-new issue and I’m really stumped. Has anyone else come across this? Thanks for any advice.
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 1 Reply
  • John Fishback
    June 10, 2009 at 5:27 pm
    Do you have a second FW bus on a card, or are you plugging one device in the front and the other in the back? All the FW connections on the mac are one buss. If you plug in two devices, you may get a negative reaction. Not always, but sometimes. It can be intermittent.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
