Activity Forums Apple Final Cut Pro Legacy Capture: How long firewire cable can be ?
  • Capture: How long firewire cable can be ?
    Posted by Pierre-luc Pare on January 8, 2007 at 8:21 pm
    I read that someone used 80 feet firewire cable, but that s not recommended. I would setup a 60 feet fw cable that will start from my Mac and end up to a fw hub in my workstation, where I can plug DVcam deck, dvd burner, and other drives. What do you think ? I’m talking about FW400.
    Don’t fear the tiger, the Cow is near!
    Studio Plasma
    Mastering & DVD
    Montreal (QC) Canada
    http://www.studioplasma.ca
    Pierre-luc Pare replied 19 years, 8 months ago 5 Members · 11 Replies
  • 11 Replies
  • Pierre-luc Pare
    January 8, 2007 at 8:29 pm
    I found it, 15 feet max.
    Sorry
    Studio Plasma
    Mastering & DVD
  • Thaxter Clavemarlton
    January 8, 2007 at 8:56 pm
    Just to stir the pot…
    I do work at a production house where the decks are all in the “tape machine room” and we routinely run FW cables up to 80 feet to FCP Macs every day.
    With that same company, we recorded on-location at a ball-park with multiple cameras feeding a switcher with FW inputs.
    One of the camera’s FW cables was about 200 feet long (two 80-footers and a 40-footer, end-to-end) and the other two were each on 80-foot FW lines.
    The image and audio (we fed the wireless mics into one of the cameras) was just perfect over three days of outdoor shooting.
    Its a digital signal, so its either “there” or its not. No deterioration like in analog line-loss.
    We were skeptical as well, but we tried it, it worked great, and now we have used a similar set-up (not EVERY shoot requires THAT much distance, of course) several times.
    No speculation, just my experience.
  • Pierre-luc Pare
    January 8, 2007 at 9:04 pm
    That’s pretty long, 200 feet. And how long was the longer shot ? I mean, maybe it works well just for capture/playback under certain amount of continuous time…
    Studio Plasma
    Mastering & DVD
    January 8, 2007 at 9:44 pm
    The long FW cameera runs simply “worked” during the shoots.
    And the long runs in the edit bays work with FCP and DV decks.
    It just works like a 6-footer does if you had the deck right next to the Mac.
    Where did you find “15 feet” as a recommended max. length?
    Obviously, the shorter the better.
    My point is that we have actually (and consistently) USED long-run FW cables and had no problems.
    As always, “your mileage may vary.”
  • Pierre-luc Pare
    January 8, 2007 at 10:17 pm
    Well I found it on a Apple Discussion troubleshooting article and another website talking about Firewire protocol. Forgot the links.
    Studio Plasma
    Mastering & DVD
  • Rich Rubasch
    January 9, 2007 at 12:21 am
    YOu can also get extenders that come in 15 foot lengths and string as many of them as you need.
    Rich Rubasch
    Tilt Media
    January 9, 2007 at 1:41 am
    I think what Pierre-Luc was saying is that he thought 15 feet was the MAX length that FW was supposed to be used.
  • Walter Biscardi
    January 9, 2007 at 1:46 am
    [Thax]
    With that same company, we recorded on-location at a ball-park with multiple cameras feeding a switcher with FW inputs.”
    I’d like to know how you guys can do this because we’ve tested 50 and 75 firewire cables here and cannot get anything longer than 15 feet to work. We had the DSR-11, now have the Sony 15U HDV deck and the Panasonic 1200A deck. neither of them can be controlled or even recognized by FCP with anything longer than 15 feet.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Walter Biscardi
    January 9, 2007 at 1:48 am
    [walter biscardi] “because we’ve tested 50 and 75 firewire cables”
    should read 50 and 75 foot cables
  • Sean Oneil
    January 9, 2007 at 7:38 am
    I’d like to know as well. I’ve tried a 30ft cable by itself with no luck.
    I use Gefen FW extenders. You attach it to the end of a 15ft cable, and then you can daisy chain 33ft cables up to 250ft (it has a booster to allow 33ft cables to work). Messy but it works.
    Sean
