Activity › Forums › AJA Video Systems › Capture from DA-98 via optical?
  • Capture from DA-98 via optical?
    Posted by Steve Covello on June 8, 2006 at 7:18 pm
    Anyone have success capturing from DA-98 via optical? I know the IO device is setup for ADAT, but all my source tapes are DA-88 recordings. I figure I could get the DA-98 with the optical option, but I don’t know if the data format is the same as the Alessis product or whether it is an industry standard.
    thx – Steve
    double wide post
    Meesta Joe replied 20 years, 3 months ago 3 Members · 4 Replies
  • Bob Zelin
    June 8, 2006 at 11:24 pm
    It’s the ADAT industry standard.
    Bob Zelin
  • Steve Covello
    June 9, 2006 at 11:51 am
    Thanks for the reply Bob, but I’m not sure what you mean in your reply. Do you mean that it is Alessis’ standard or the industry’s [AES]standard? How could it be both if Alessis is not “the industry” per se given that there are other products like DA-88?
    Thx – Steve
  • Bob Zelin
    June 9, 2006 at 4:20 pm
    8 channel optical is usually refered to as ADAT, which was developed by Alesis for their old 8 track recorders that used VHS format. The ADAT optical format is used by AVID, and AJA as well. Tascam sells ADAT to TDIF interfaces. Alesis sells ADAT to AES/EBU interfaces.
    Bob Zelin
  • Meesta Joe
    July 3, 2006 at 1:50 pm
    I’m wondering if this is too late for ya, but with a DA98- you’re set to go. Just use the AES outs from the 98 into the AES Ins on the IO. With a DA88, you’d need the Tascam IF-AE8 convertor to convert TDIF to AES.
