Activity › Forums › Apple Final Cut Pro Legacy › Capture Frame size & Audio Setting, MPEG Stream Clip Compression & frame size & FCP Project settings
  • Capture Frame size & Audio Setting, MPEG Stream Clip Compression & frame size & FCP Project settings
    Posted by Joe Sullivan on July 30, 2011 at 5:06 pm
    Hello All, I wonder if you can help me please? I will try and make this as simple as possible,
    Basically I want to record a hour (+) program from my standard sky box and put it on to a standard 4.7 GB DVD in after chopping it (the adverts) to be played in the UK ( not US)
    I am going from my sky box (scart) to DVD recorder ( Toshiba D – R 1SB) coming out of that with a 3 jack lead ( red & white audio, yellow video) to USB EMPIA CAPTURE 1.0.0b18
    These are my Empia capture setting & options:
    Record, Video Settings, Adjustments = Defaults
    Compression type: MPEG 4 (I can change this, eg: DV PAL, PRO Res
    422, HDV ETC)
    Motion: Frames Per Second: 25 (I can change this)
    Key frame every….. Frames= blank
    Limit Data rate to….. KBtes/ sec= Blank
    Empia: USB Bandwidth= 100 percent
    Horizontal / Vertical Offset: 0
    Quality= Best
    Auto detect input and format= yes
    Source= Empia Composite
    Record, Sound settings, Compression= None
    Sample Rate= 48.000 kHz
    Size= 16 bit (not 8 bit)
    Use= Stereo (not mono)
    Speakers= off while recording
    Volume=100 (highest)
    Gain= 150 (highest)
    Source = DV Audio USB 2861 Device
    Select Video Frame size = 640 x 480
    Custom size: width x height
    Note: Digitizers that restrict widths and height may not honor the exact dimensions typed. USB vision devices require a multiple of 4 columns wide and 2 rows heigh.
    The frame size 640 x 480 seems to work well!
    if I go to custom and change it to w 720 x h 576 for example at this stage the message says: ” the frame size does not have the standard width to heigh ratio of 4 to 3. The capture may not be scaled correctly.” and when I try and open open the capture “Movie could not be opened! not a movie file”
  • So I think I am better staying at 640 x 480
  • Record, = Full size (Quarter, half, full, double size, full screen I think this is just the view/ size of window)
    Record Duration= 5 hours
    Note: The movie will be recorded until this time has elapsed.
    Record, set up Auto name = off
    Are all these capture settings correct ? or should I change the compression type?
    If I capture a clip using these setting then bring it in to Final Cut PRO 6.0.6
    and drop it in to the time line I am prompted to ” change sequence setting to match clip settings”
    if I click yes and go to the sequence settings = 640 x 480 NTSC 4:3
    I WANT TO DO THIS THE EASIEST AND QUICKEST WAY AND BRING THE CLIPS STRAIGHT IN TO THE EDIT MEANING NO RENDERING IF POSSIBLE ?
    If not I have got MPEG Stream clip Version 1.9.2 (1.9.2)
    Which I can use to “export to QT, and
    change the: compression: (?)
    : Frame Size: 640 x 480 (4:3)
    854 x 480 (16:9)
    640 x 480 (unscaled)
    720 X 567 (DV PAL) etc
    I am using compressor version 305 & DVD Studio PRO 4 version 4.2.0
    Should I just start a new sequence with settings: frame size, 640 x 480 aspect ratio 4:3
    compression of sequence matching the compression
    of capture ?
    E.G DV PAL
    I just want to know how to get the sky broadcast (roughly 1 hour) in the best quality (full screen, no dropped frames, in sync etc) the simplest and quickest way on to DVD ?
    I don’t think I have the option to make the sequence settings HD, (HDV PRO RES 422) as my version of DVD PRO has problems with HD so SD will be fine I think.
    I just want to use the equipment and software I have got really and not have to download / upgrade etc.
    Sorry for all the detail
    Many thanks in advance
Joe Sullivan replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
