Activity Forums Apple Final Cut Pro Legacy Capture format not lining up
  • Capture format not lining up
    Posted by Pete Rose on August 18, 2011 at 11:48 pm
    Hey everyone,
    I’m trying to capture directly from a Kona3 rig where the format is 1080psf 23.98 at 1920×1080. I want it to be 1280×720. However, regardless of the setting I attempt to put the capture at, when I go to the actual files in finder and open them in Quicktime they are still at 1920×1080.
    Any ideas why?
    Pete Rose replied 15 years ago 4 Members · 5 Replies
  • David Roth weiss
    August 18, 2011 at 11:56 pm
    [Pearce Roemer] “regardless of the setting I attempt to put the capture at”
    You’ll have to state specifically exactly what that means to you, because we have no idea what you’ve tried.
    For instance, did you attempt to use the AJA Control Panel to set the Kona3 to properly down-convert?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Shane Ross
    August 18, 2011 at 11:58 pm
    CROSS CONVERT…let’s get the terminology right.
    You have to CROSS CONVERT in the Kona Control panel..
    Shane
  • Steve Eisen
    August 19, 2011 at 12:11 am
    Down Convert is when you go from HD to SD.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    August 19, 2011 at 12:23 am
    Yes, but 1280×720 is HD….to 1080 to 720 is a cross convert.
    Shane
  • Pete Rose
    August 19, 2011 at 1:31 am
    Thank you so much. A little tooling around in the AJA Control Panel for awhile sorted things out. Much appreciated!
