Activity Forums Apple Final Cut Pro Legacy Capture Final Cut Pro
  • Capture Final Cut Pro
    Posted by Pablo cesar Bazzani on January 4, 2010 at 1:08 am
    Good thank you very much for wanting to help, I have a question. Mini plug my camera DV via firewire 800 to my imac does not recognize the camera can not capture (the setings are already configured). Each time I connect the camera does not recognize that I get a warning that says DV in, But neither the Final Cut nor the movie I recognize. My question is, Mn chamber DV should read DV out to see the DV in, Ie will the camera settings, Or is that the firewire 800 cable is damaged. Thank you very much for your answers.
    Greetings
    Paul Cesare Bazzani
    Pablo cesar Bazzani replied 16 years, 8 months ago 2 Members · 2 Replies
  • Roli Rivelino
    January 4, 2010 at 2:19 pm
    Have you used the camera before?
    Are you connecting the camera before you boot up Final Cut?
    If the answer is yes to both of these, try another cable.
    If the answer is no to the first question, then try another camera, if the answer is no to the second question, then connect and turn on the camera before you boot up Final Cut.
    good luck.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Pablo cesar Bazzani
    January 6, 2010 at 9:59 pm
    muchisimas gracias estoy seguro que el cable esta dañado. me parecio extraño lobarato que lo consegi. les estare contando como me fue por que tengo que hacer unas capturas urgentes.
    una pregunta mas, es imposible con el cable de usb capturar. (mi camara es de casete mini dv).
    Gracias y un feliz año nuevo.
