Activity › Forums › Avid Media Composer › Capture error message on Avid Xpress Pro HD
Posted by Gooseberry on April 9, 2006 at 4:31 pmI’m trying to capture using a sony DVcam and all my settings seem to be fine but each time i choose the video and audio chaneels to record, the following message appears :(Exeption : ERROR : SWCofidence view:Confidence view unable to initialise overlay)
Am I doing something wrong?
Jon Zanone replied 20 years, 4 months ago 2 Members · 9 Replies -
Jon Zanone
April 10, 2006 at 11:39 amWhat are your system specs? What is the camera you are using? How are you bringing the signal into the Avid (FW or analog)?
Jon
Gooseberry
April 11, 2006 at 12:49 amThanks Jon.
I’m using SONY PD150 through Firewire.
My specs are : Intel P 3.4 prossessor, 1024 DDR RAM, and 400GB of hd.
The device is being picked up and can control it remotely but every time I click the channels and press record. the message comes on.
Jon Zanone
April 11, 2006 at 11:25 amMake sure your camera is on before you start your Avid software. You are a little light in the RAM department, but I don’t think that’s the issue.
HTH,
Jon -
Gooseberry
April 11, 2006 at 4:10 pmMy camera is on before starting Avid but still get the same message. At some instances i get a Fatal error message when I try to drag and drop imported footage on to the time line which I would have captured using a different package.
Jon Zanone
April 13, 2006 at 11:24 amFrom the Avid website…
https://www.avid.com/content/8927/SUPPORTED%20DEVICES%20FOR%20AVID%20EDITOR%20PRODUCTS.pdf
I pulled this from the .pdf…
Sony DSR-PD150
Note: Further testing is
being done with this
device due to a recent
issue. Please check
back for any resolution.Have you gotten this error from the beginning? Have you tried check decks in the digitize tool? Have you tried trashing your MCState files? (in C:/Program Files/Avid/Avid XPress Pro/Settings) Tried a new user setting? Have you tried different deck settings (like generic)?
Thats all I can think of right now…
HTH,
Jon -
Gooseberry
April 14, 2006 at 12:57 amYes I’ve had this error from the beginning. Infact, I’ve haven’t done anything with it as yet. I tried trashing the MCState files, new user setting, different deck settings.
As if that’s enough. Having done all that, I tried to play imported footage and, a new error appeared:- (An ACCESS_VIOLATION exception occurred: see FatalErrorReports.)and as well as :-(Exception:DesktopSFConsumer::PlaySampleFrame unable to initialize spring buffer)
Am I going to use this program at some point.
Jon Zanone
April 14, 2006 at 11:20 amAre you sure your footage was recorded in SP, and not LP?…. I’m running out of ideas here (unless you caught the line from a previous post regarding problems Avid has found with the PD-150…)
Jon
Gooseberry
April 22, 2006 at 2:12 amThanks so much for your trying Jon. What I have done is wipe off evrything on my PC and start afresh with the installation of Win XP then the different applications. Since then, haven’t had any problems. I gather it was an internal error with my system.
many thanks.
