Activity Forums Panasonic Cameras Capture DvcPro HD 24fps 60hz over firewire?
  • Capture DvcPro HD 24fps 60hz over firewire?
    Posted by Ian Grey on February 3, 2007 at 8:26 pm
    Im looking to get a deck to capture footage shot on the Varicam at 720/24p over 60hz and have been coming over different information regarding whether the panasonic decks can output both 59/60hz and not just the 59hz recorded material.
    Does anybody know if its possible too capture the footage I have via firewire?
    Best Regards
    Ian Grey
    Steven Rushworth replied 19 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    February 3, 2007 at 10:11 pm
    [iangrey] “Im looking to get a deck to capture footage shot on the Varicam at 720/24p over 60hz and have been coming over different information regarding whether the panasonic decks can output both 59/60hz and not just the 59hz recorded material.”
    the 1200, 1400 and 1700 decks all support the 60hrz timelines if that is what was set incamera – you will have to nudge some of the settings however due to the fact that most of the NLE’s expect/ want 59.94 as opposed to the 60.
    You can achieve this by creating your own timeline in Express Pro / Adrenaline or FCP.
    As for Premiere and the other NLE’s I am not sure.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Chris Bierlein
    February 5, 2007 at 6:30 am
    The 1200A deck will not output through the Firewire if it’s set at 60hz, though I’m not sure about the 1400 and the 1700. The 1200 will only output through the Firewire if it’s set at 59.94. This is menu item 030, which must read 59/23 rather than 60/24.
    http://www.chrisbierlein.com
  • Gary Adcock
    February 5, 2007 at 3:57 pm
    [Chris Bierlein] “The 1200A deck will not output through the Firewire if it’s set at 60hz, though I’m not sure about the 1400 and the 1700. The 1200 will only output through the Firewire if it’s set at 59.94. This is menu item 030, which must read 59/23 rather than 60/24.”
    Only if the camera tape is 59.94.
    if the camera tape is set to 60hrz the output from the deck is 60hrz not 59.94 – the video output is based on what was shot in the camera.
    gary adcock
    Studio37
  • Chris Bierlein
    February 6, 2007 at 12:17 pm
    [gary adcock] “Only if the camera tape is 59.94.
    if the camera tape is set to 60hrz the output from the deck is 60hrz not 59.94 – the video output is based on what was shot in the camera.”
    Through Firewire?
    CB
  • Ian Grey
    February 10, 2007 at 11:44 pm
    This is why I was confused as I have come across this on the web. Some people say it works and some people say I doesn’t
    Gary have you succesfully output 60hz via firewire yourself?
    Ian
  • Gary Adcock
    February 11, 2007 at 1:57 am
    [iangrey] “This is why I was confused as I have come across this on the web. Some people say it works and some people say I doesn’t
    Gary have you succesfully output 60hz via firewire yourself?”
    DId it today as part of my post session at the Varicamp in LA.
    The Camera Tape must have been shot at 60hrz to get 60hrz out of the deck. I was using a 1400 deck, and you CANNOT have the deck convert between
    between the 59.94 and 60Hrz.
    gary adcock
    Studio37
  • Steven Rushworth
    February 25, 2007 at 3:16 am
    60hz over firewire into FCP with a 1200 does work last time I tested, so unless some recent update has fixed this issue, I assume this is still the case. Yet to test with 1400.
