Activity Forums Avid Media Composer Capture DV PAL as 3:1 MXF?
  • Capture DV PAL as 3:1 MXF?
    Posted by Loekie Love on October 26, 2009 at 10:12 am
    Hey there,
    does anyone know a way to capture DV PAL as 3:1 MXF? I’ve treid an online search, unfortunately no result..
    I’m tapelogging for a project that uses other media than DV PAL aswell, and the main editor whishes to have everything delivered as 3:1 MXF.
    thanks in advance! L.
    Michael Phillips replied 16 years, 11 months ago 4 Members · 4 Replies
  • Paul Harrington
    October 26, 2009 at 11:18 pm
    Depends what deck you are coming from, if over Firewire just change your capture tool to DNA-1394 FW, you go to straight that res. If your deck has SDI out go that way. FW can be a bit of a pain.
  • Job Ter burg
    If you are bringing in the media by capturing an SDI source into Mojo, Mojo SDI, Mojo DX, Nitris or Nitris DX, you can simply select that resolution.
    If you are bringing in that footage over FireWire, you are actually capturing the DV-stream, so you cannot choose anything but that same type of resolution.
    You can mix DV25 with 3:1 MXF if you want. But if you feel you need to have those clips in a different resolution, select all captured clips, and choose Transcode. Then transcode the files into 3:1 MXF.
  • Loekie Love
    October 27, 2009 at 10:05 am
    Thank you guys very much for the quick responses! – I’ll put them to test when I arrive at work later today.. The advices are very helpfull(!)
    Thanks again 🙂
  • Michael Phillips
    October 27, 2009 at 9:20 pm
    I capture DV24 over FireWire all the time as 14:1 – it gets decompressed in Avid to uncompressed, then captured as 14:1. A fast enough CPU should do the same for other resolutions…
    Michael
    Michael Phillips
