Activity › Forums › Apple Final Cut Pro Legacy › Capture Confusion
  • Capture Confusion
    Posted by Eric Klassen on August 16, 2005 at 1:13 am
    I have some tapes shot on the new Sony HDV camera, shot HD in 16:9, 25p PAL. I am capturing it at dv resolution. I am having a hard time with getting this footage logged at the 16:9 aspect ratio. I see some settings for NTSC that go to 16:9, but not for PAL. I tried setting it to anamorphic, but it was stretched out. Any suggestions?
    eric
    Eric Klassen replied 21 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 16, 2005 at 3:18 am
    After you capture the anamorphic footage, scroll to the right in the browser and under the ANAMORPHIC column, check each clip.
    BOOM. They will go to the proper aspect ratio…
  • Eric Klassen
    August 16, 2005 at 4:07 pm
    Maybe I’m not clear here. The footage is not anamorphic. The sony HD captures shoots 16:9 normally. If I want to be able to capture the 25p PAL footage at 16:9, what must I do? I am getting either a stretched out anamorphic look, and if I check the box, then I get a 4:3 frame that clips footage off both the left and right side.
    eric
