Activity › Forums › Apple Final Cut Pro Legacy › Capture clips from DVR
  • Capture clips from DVR
    Posted by Tom Von doom on August 18, 2008 at 7:55 pm
    Here’s an odd question. I’m working on some spec political spots. The director wants to access news clips on a DVR at his home remotely using a Slingbox and import them into FCP here in my edit suite. Is it possible? I’m not that familiar with Slingbox. Is there a better way to get the clips off the set top box and into FCP? Is there a workflow for this?
    TVD
    David Bogie replied 18 years, 1 month ago 2 Members · 1 Reply
  • David Bogie
    August 19, 2008 at 4:17 pm
    These kinds of lame-brain “shortcuts” are always incredible hassles. Slingbox’s site used to have a user manual you could download. If it’s got a composite output run that to your DV deck or a convertor. Easier if he makes dubs to VHS or DV at his end rather than expecting you to cope with his dumb idea of using a DVR.
    bogiesan
