Activity Forums Creative Community Conversations Capture Card—- NTSC Monitor
  • Capture Card—- NTSC Monitor
    Posted by Rick White on June 3, 2008 at 2:32 am
    Hey guys I gotta EDITING Question & about my set up… I have a basic 2 monitor set up. I also have a broadcast monitor that I would like to add for playback only…. Do I have to buy a pricy capture card or is their a cheaper but good option???
    Thank you very mmuch….
    RW
    Rick White replied 18 years, 3 months ago 2 Members · 2 Replies
  • Ross Neugeboren
    June 3, 2008 at 8:47 pm
    I would recommend going with a mid-grade capture card. While there are some homebrew solutions – such as using a video out from your graphics card or converting from DVI>VGA>S-Video, the most reliable solution would be a capture card. You could get along with something like the Blackmagic design Decklink ($295) a basic card with SDI Monitoring out, SDI In and Out and RS-232 deck control. From there you can go up through the numerous Blackmagic SD cards – ranging from $295 to $895, gaining XLR audio,composite, etc. S/PDIF as you go up. Don’t know anything about AJA cards.
    Ross Neugeboren
    GetTheShot
  • Rick White
    June 3, 2008 at 9:43 pm
    WOW Thanks, you really know your stuff…
    Thanks again
    RW
