Activity Forums Adobe Premiere Pro Capture Blue-ray 3D footage and edit it !!!! – WORKFLOW!
  • Capture Blue-ray 3D footage and edit it !!!! – WORKFLOW!
    Posted by Ariel Brener on October 3, 2010 at 8:22 pm
    Hey all,
    This is pretty ambitious but I have a client that wants to give me so Blue-ray 3D movies. and wants me to edit them a bit. shorten them etc..
    when I say 3D I mean REAL 3D for 3D monitors and active glasses..
    So where do I start?
    Can I rip from a BLUE-RAY DRIVE?
    Can I capture with a card that has a HDMI input such as this:
    DeckLink HD Extreme 3D
    https://www.blackmagic-design.com/products/decklinkhdextreme/
    Can I edit this 3D footage and add my own 3D title and footage
    Does PPRO or AE supports it?
    how do I export HD 3D ?
    I got an answer from other forum regarding capturing HDMI input:
    You cannot capture commercially available BluRay discs over HDMI with any card. The signal has HDCP (copy protection) and will not allow it.
    So I need to either RIP it from the BLUERAY 3D drive.
    or connect the BLUE-RAY 3D player to the SDI input.
    Is there a HDMI to SDI converter?
    will it convert t with the 3D data in it?
    BTW how is the 3D data stored?
    Is it just two video streams running at the same time?
    is it somehow embedded and coded n the blue-ray disk codec?
    how does it work and how can I capture it?
    Can I somehow RIP it fom the Blu-ray Drive?
    how does Premiere Pro CS5 handle it?
    Brian Louis replied 15 years, 11 months ago 2 Members · 1 Reply
  • Brian Louis
    October 3, 2010 at 9:35 pm
    If you are asking to violate digital rights management, this is not the place for that question, there are plenty of other sites on the net that can answer your questions
