Activity › Forums › AJA Video Systems › Capture and monitor 4 channels of audio
  • Capture and monitor 4 channels of audio
    Posted by Tom Dempsey on October 23, 2009 at 3:32 pm
    Hi, I’m using a 2 x 2.6 Ghz Quad-Core Intel Xeon Mac with 12 GB of Ram. Also using a Kona LHi
    card and monitoring with an 8 Channel Mackie audio board. I’m wondering if i can monitor
    4 channels of audio during a capture? either discreetly or mono. Doesn’t make a difference.
    Is there any work around?
    tomd
    Tom Dempsey replied 16 years, 11 months ago 2 Members · 2 Replies
  • Doug Beal
    October 23, 2009 at 8:01 pm
    Lhi is 2 channels analog and AES you can change pairs to monitor, in the control panel but not 4CH at once.
    you would need a de embedder to do that, de embedding the SDI stream to 4 CH analog to get that into your mackie,
    or monitor a tape machine in E-E via analog outputs of the tape machine while mixing, or off tape while capturing
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Tom Dempsey
    October 24, 2009 at 5:06 am
    thanks. i appreciate the response.
    tomd
