Activity Forums Blackmagic Design capture analogue with Decklink Pro?
  • capture analogue with Decklink Pro?
    Posted by Jody Kerr on September 22, 2005 at 7:47 am
    Can anyone tell me if this is possible?
    I want to hook up a VHS player to capture via my decklink pro.
    Any advice much appreciated!
    Luke Maslen replied 20 years, 11 months ago 4 Members · 3 Replies
  • Wolf
    September 22, 2005 at 8:04 am
    Hi, you need a Decklink SP or a Decklink Extreme….
    on your Decklink Pro there
  • Roddy Jamieson
    September 22, 2005 at 8:35 am
    Can you route the VHS through your main capture deck? Composite in to SDI out. Best way would be to dub onto your main format first.
    Roddy Jamieson
  • Luke Maslen
    September 26, 2005 at 6:43 am
    Hi Jody,
    The DeckLink Pro is primarily a digital card whereas your VHS player is analog. You would need to use a DeckLink SP or DeckLink Extreme to capture directly from the VHS player. Alternatively you could use a digital to analog convertor but that would probably cost much more than using a DeckLink SP card.
    Regards,
    Luke Maslen
    Blackmagic Design
