  • Posted by Andrew Zador on February 17, 2011 at 10:39 pm
    Hello,
    I have a problem. I can not capture anything since I performed an OS upgrade. I have tried a lot of different ways to set up the capture preset, but I always get the same message: Unable to initialize capture device. I am using HDV and a MAC OS X 10.6.5. What am I doing wrong? Please help me.
    Thank you
    Andrew
    Zane Barker replied 15 years, 7 months ago 3 Members · 2 Replies
  • Chris Tompkins
    February 17, 2011 at 11:16 pm
    did you try an “easy setup” first?
    Make sure it matches the format you are capturing from.
    Chris Tompkins
    Video Atlanta LLC
  • Zane Barker
    February 18, 2011 at 4:06 am
    [Andrew Zador] “I am using HDV”
    Is your camera set do down convert HDV to DV?
    [Andrew Zador] “I performed an OS upgrade”
    You should know that Pro Apps like FCP can have problems if you simply upgrade a OS or upgrade your version of FCP. It is best to clone your drive, erase it and then start fresh.
    **Hindsight is always 1080p**
