Activity › Forums › Apple Final Cut Pro Legacy › canvas turns BLANK
  • canvas turns BLANK
    Posted by Sarah Leisdovich on November 30, 2006 at 3:29 pm
    I have this problem…
    When I view the captured material in the timeline, the canvas turns completely white whenever I click the space-button to stop the material, to see an individual frame. When I press the space button again, the canvas shows the material again, as if nothing happened, but when I stop again, again the canvas turns blank. This is a little inconvenient, as i only seem able to see the material in movement in the canvas. This problem is recent and I don’t know if I did something wrong that provoked it (and then maybe there’s a way to undo it?) or if it is some kind of error of the program itself.
    Very grateful for your help,
    Sarah
    (I use Final Cut Pro 4,5HD on a Powerbook G4)
    Phillip Van west replied 19 years, 10 months ago 3 Members · 4 Replies
  • Chris Poisson
    November 30, 2006 at 9:23 pm
    Sarah,
    It may be that under the view menu, you have “Show multiclip angles” checked. If so, turn it off.
    Or, check that your canvas is set to fit to window, that you’re in Safe RT and nothing is overlaping.
  • Phillip Van west
    November 30, 2006 at 9:41 pm
    Also, make sure that in the right-most of the three pulldown menus at the top of the Canvas window, it’s set to RGB, not Alpha.
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.8 / FCP 5.1.2 / QT 7.1.3
  • Sarah Leisdovich
    December 1, 2006 at 3:51 pm
    Waw, amazing, thank you so much! I had indeed ‘alpha’ activated in the canvas, in stead of ‘RGB’. Many kind regards, Sarah
  • Phillip Van west
    December 1, 2006 at 10:12 pm
    We aim to please. ‘-)
    Phil Van West
    Denver, CO
