Activity › Forums › Apple Final Cut Pro Legacy › canvas maginfied- settings at 100%?
  • canvas maginfied- settings at 100%?
    Posted by David Mcguire on August 17, 2010 at 8:10 pm
    Im editing footage imported from XDCAM into FCP Studio 6.06. Ive been working on other formats recently and came back to a project. The canvas is suddenly much larger although the viewing is 100%. The project settings are as follows: Frame size 1920X 1080, aspect ratio HVV 1080 60i (this mounts as the compressor setting is selected) XDCAM EX 1080p (35 VBR)
    Pixel Aspect square.
    The Project Video settings are XDCAM 1080p VBR with a capture preset of HDV – Apple Pro Res 422 HQ.
    The viewer looks fine but the canvas is magnified.
    What have I done to cause this?
    thanks
    Jerry Hofmann replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 17, 2010 at 11:41 pm
    You’ve expanded it. It can be done if the zoom tool is active and you click on it, and other ways… Select the Canvas, and type shift+z. Then set the window arrangement to standard or whatever you like to work in.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
