Activity Forums Adobe After Effects can’t we have a transparent solid in AE as in combustion?
  • can’t we have a transparent solid in AE as in combustion?
    Posted by Canwal Brar on December 28, 2005 at 10:57 am
    In combustion there is an option regarding the color of solid either one needs a transparent solid or a colored one, cant one acheive a transparent solid in AE.
    canwal brar
    Mylenium replied 20 years, 9 months ago 2 Members · 1 Reply
  • Mylenium
    December 28, 2005 at 11:45 am
    What would be the purpose of such a layer type? You can already use Nulls (which don’t render i.e. are 100% transparent) and any effect I can think of can either render transparent alpha directly or made to create alpha using unmultiplying and other matting techniques. In case you are thinking that a transparent layer would fix effects that don’t create proper alpha transparency, you are wrong. This must be explicitely coded in the plugin and if it’s not, it would still render opaque on a transparent layer.
    Mylenium
    [Pour Myl
