Activity › Forums › Blackmagic Design › Can’t use FCP Voiceover tool with picture playback?
  • Can’t use FCP Voiceover tool with picture playback?
    Posted by Bruce Colgate on September 7, 2007 at 2:52 am
    Howdy.
    My problem (among others) is that I *really* want to use FCP’s Voiceover as it was intended – to VO to an existing edit while listening to production audio and the existing picture cut.
    But it seems that Multibridge can’t output video at the same time you record audio:
    https://www.blackmagic-design.com/support/detail.asp?techID=164
    Am I the only one that thinks this is an odd limitation? Am I misreading the technote? Are there any other workarounds short of buying another audio interface device to get quality audio in?
    Thanks for the bandwidth,
    -Bruce
    Massimo Croce replied 19 years ago 2 Members · 1 Reply
  • Massimo Croce
    September 7, 2007 at 10:55 am
    Use the built in audio (it’s a mini jack unbalance!! ok i know this) swich the VO input ti internal line in….
    you can t monitor the audio output throug decklink, but if you have a mixer you can do…
    that’ s all
