Activity › Forums › Apple Final Cut Pro Legacy › can’t update FCP to 7.03
Posted by Greg Ball on December 10, 2010 at 5:24 pmI’ve got my disks and serial number for FCP Studio 3. I’m trying to update to 7.0.3. Whe I try to download it tells me that the serial number is not valid. Any thoughts?
Craig Alan replied 15 years, 9 months ago 8 Members · 15 Replies -
Shane Ross
December 10, 2010 at 5:47 pmUse the SOFTWARE UPDATE option in the System Preferences.
Shane
Read my blog, Little Frog in High Def -
Greg Ball
December 10, 2010 at 6:15 pmI tried that, but it says everything is up to date. However, my FCP lists as 7.0 and I know we’re up to 7.0.3
Shane Ross
December 10, 2010 at 6:20 pmHmmm…check the PROAPPS update? That’s what they are called.
Shane
Greg Ball
December 10, 2010 at 6:53 pmShane, I’m not sure what you’re saying here. All my apps are up to date but I’m only on FCP 7.0
Doug Beal
December 10, 2010 at 7:23 pmhe means look in boot drive>library>receipts>installHistory plist for ProApplicationsUpdate2010-02
if you’re on snow leopard to see if you’ve installed itDoug Beal
Editor / Engineer
Rock Creative Images
Nashville TN -
Greg Ball
December 10, 2010 at 7:36 pmI have the ProApplicationsUpdate2010-02 installed as of September. What does that tell us? My FCP still lists as 7.0
Zane Barker
December 10, 2010 at 8:06 pmHave you by chance moved your FCP apps out of the default apps folder or put them inside another folder within the apps folder.
For software update to work the FCP apps must be in the apps folder just like they were when you finished installing them.
**Hindsight is always 1080p**
