Activity › Forums › Adobe After Effects › Can’t undo in after effect
Posted by Rj Alfian on June 11, 2011 at 9:46 amHalo everyone,
I need help! Suddenly i can’t undo my work in after affect cs5 mac.
When i click undo, its always appear; CHANGE VALUE in right side pallete.
Im a beginner, so i really dont have any idea what to do to fix it.Thanks for any help and fast response..
Todd Kopriva replied 15 years, 2 months ago 4 Members · 5 Replies -
Todd Kopriva
June 11, 2011 at 8:16 pmI’m not clear on what you’re saying.
Are you saying that pressing Ctrl+Z (or Command+Z on Mac OS) isn’t undoing your most recent action?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Rj Alfian
June 11, 2011 at 10:17 pmYes absolutely right.
I can’t undo just in one project i’m working on. Command z and undo button is not work. But if i open the new project with new comp, everything fine.
I already try to copy my ‘can’t undo’ comp to new comp but also did’t help. -
Carlos Fernandez
June 22, 2011 at 5:53 pmI have the same problem. Are you using Trapcode Form? Try disabling it.
Jeremy Allen
July 7, 2011 at 5:44 pmI’ve just started using Form and I’m having the same problem. If I turn off the form layer, I can undo. And as Rja said, when form is enabled, all my undo history says is “Change Value” no matter what actions I actually completed.
Also, when I hit undo, I get a quick little render bar like its doing something, but nothing changes.
8core MacPro, 3.0 GHZ, 18GB RAM, OSX 10.5.8C4D 11.5
AE CS5 (10.0.2.4)
FCP 7.0.3
QT 7.6.4 -
Todd Kopriva
July 7, 2011 at 5:50 pmIt would be a good idea for you to submit a bug regarding Trapcode Form to the makers of that plug-in.
