Activity Forums Maxon Cinema 4D Can't subtract object
  • Justin Thomson
    July 5, 2021 at 3:42 pm
    Not exactly sure what the issue is, where did you get the splines? A free vectors site?
    I redrew the shapes and then dropped them in the extrude/boolean and then adjusted the position of the smaller shape by decimals points and I got a result.
    You might want to start by redrawing the splines, even using optimize didn’t clean it up enough.
  • Hung Nguyendac
    July 6, 2021 at 8:46 am
    I imported the splines from Illustrator. Seem like redraw is the only one way to make it work in c4d, so sad ?.
    Thank you Justin.
  • Justin Thomson
    July 7, 2021 at 4:38 pm
    Or redraw it in illustrator if you prefer, either way the spline is a mess and needs to be corrected.
  • Hung Nguyendac
    July 10, 2021 at 2:07 am
    I just installed R18 version while finding easier method. R18 work like a charm, i don’t know what wrong with S24 & R23. But in R18 i just need drag path to Extruder, then delete inside path. Thank you Justin
