Activity › Forums › Adobe Premiere Pro › Can’t Seem to Add Audio Effects to Multicam Sequence
  • Can’t Seem to Add Audio Effects to Multicam Sequence
    Posted by Harrison Gruber on March 15, 2018 at 11:57 pm
    Hi. I have some mono tracks where the sound is only coming out of one speaker. I wanted sound to come from both so I tried adding the “Fill Left With Right” Effect to the audio track but it didn’t do anything. So then I tried adding it to the original source clip by double clicking the audio in the multicam sequence –>opening the source sequence and adding it there…no dice.
    ANY IDEAS?
    Todd Perchert replied 8 years, 6 months ago 2 Members · 2 Replies
  • Todd Perchert
    March 16, 2018 at 4:25 pm
    You sure it’s mono? Is it only on the left (ch.1) channel? Find the clip you need in your Project bin, right-click on the clip and go to Modify, then select Audio Channels. Select format as Mono and make sure your L channel is checked. Hit OK. If your audio was on the right channel, you would select R instead of L. This will make a single channel mono.
    TC
  • Todd Perchert
    March 16, 2018 at 4:26 pm
    I should mention you will need to re-edit into your timeline after you do modify the audio.
    TC
