Activity Forums Maxon Cinema 4D Cant see Weight points on ‘clones’ with Fracture Object :s
  • Cant see Weight points on ‘clones’ with Fracture Object :s
    Posted by Elin Grome on June 30, 2011 at 4:11 pm
    Hi all,
    I have a collection of editable poly objects under a fracture object in order to apply effectors.
    Works ok but I want to use weight transform on a random effector to give some randomness to movement with other effectors..
    but for some reason I cant see the weight points when I turn on display: weight in the transform tab – when using a cloner seems ok…
    Thanks 4 your help…
    It’s all the those pesky details :p
    Elin Grome replied 15 years, 2 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    June 30, 2011 at 10:43 pm
    I can see the weight points here (R12), but only if the fracture object is selected.
  • Elin Grome
    July 6, 2011 at 12:21 pm
    Hi Adam,
    wierd :s
    Ive checked a triple checked but cant get the weight points to display.
    Even if i open a new file, create a couple of cubes and put in a fracture object, then with FO selected, change display to ‘weight’ – still dont appear.
    Anyway, that aside – I have a bigger issue with the fracture object – namely that im working with quite a funky setup of effectors from a tip I got from tim clapham using time effector and stuff…
    When I replace the cloner obj. in that setup with a new one all works fine… but when I put in a fracture object – even if its created directly from that same cloner obj. – only some of the effectors in the list work – namely those shaders that create rotation and visibility – but the time effector and visibilty shaders dont seem to execute….
    Do you know of ny documented limitations of the fracture object v cloner object ?
    I know this is vague – ive attached a scene file if anyone has some time – as u can see the cloner object works correctly – the fracture not…
    thanks (again) in advance,
    Elin
  • Elin Grome
    July 6, 2011 at 4:56 pm
    ok ive tried to upload the file about 8 times but cant even manage that 🙁
  • Brian Jones
    July 6, 2011 at 5:56 pm
    you have to copy the link you get on the last upload page back into the post you are making
  • Elin Grome
    July 7, 2011 at 12:16 pm
    thanks brian.
    Its 35 degrees here again today – with no A.C. – which doesnt help my already waning concentration. Actually ive decided to move on from that problem and workaround it.
    But of course I have another issue now – so ill repost a new thread 🙂
