Activity Forums Apple Final Cut Pro Legacy Cant see Video on Monitor
  • Cant see Video on Monitor
    Posted by Pete Sake on December 1, 2007 at 12:39 am
    Hi I’m trying to play a Hvx200 video 720p 30 frames on a Monitor from FCP6.
    I have a G5 2.7 FCP6 AJA IO LA
    It plays ok on the Mac Monitor in the Canvas sequence viewer but not on my other Monitors. composite and component out.
    I’m trying out a Panasonic LCD monitor
    Could it be the Hard Drive speed?
    Betacam footage plays ok on the monitors.
    Only 1 sequence up.
    I’ve played around with the FCP Prefs
    could this be because I need a new driver from AJA or a HD AJA box?
    I had this problem before when I tried to play uncompressed video.
    Any clues appreciated
    Peter
    Bill Bilowit replied 18 years, 9 months ago 3 Members · 5 Replies
  • Shane Ross
    December 1, 2007 at 12:44 am
    YOu are trying to play HD footage out on an SD capture card. The AJA I/O LA is an SD card. You’ll need a Kona card or AJA I/O HD.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Pete Sake
    December 1, 2007 at 12:52 am
    Thanks Shane I started to suspect that but I thought I might see it some how. So the big decision is which AJA and should I buy? and do I really need the next G5 intel? and when?
    I’ve still got other MACs with Media 100s lying around and it seems a waste to keep buying. Timing is every thing. I plan on going into HD with the P2 system. Just DVCPROHD.
    Thanks for your quick response.
    Peter
  • Shane Ross
    December 1, 2007 at 1:43 am
    [peter hitchcock] “So the big decision is which AJA and should I buy?”
    Depends on your needs. Go to aja.com and see what all the models do. They all have different capabilities.
    [peter hitchcock] “and do I really need the next G5 intel?”
    Not really. They sell PCI-X cards…Kona 3X and Kona LH.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Pete Sake
    December 1, 2007 at 4:14 am
    Thanks Shane I read your article on Matrox for monitoring. Hopefully I can do better with AJA
    Cheers
    Peter
  • Bill Bilowit
    December 1, 2007 at 7:26 am
    Also, in a pinch, I think you may be able to monitor through the camera: FCP external video set to FW > 1394 > HVX200 component out, if you have analog input HD monitor.
