Activity › Forums › VEGAS Pro › Can’t see transisitions in multic-cam mode
  • Can’t see transisitions in multic-cam mode
    Posted by John Perez on September 7, 2009 at 3:16 pm
    Hi All,
    I’m cutting multi-camera and I don’t know how to add transitions, even a simple fade. They’re not showing up. Any suggestions?
    As always thanks so much to you guys…Johnny In Orlando
    Mike Kujbida replied 17 years ago 3 Members · 4 Replies
  • Mike Kujbida
    September 7, 2009 at 3:36 pm
    A cut is the default with a dissolve (crossfade) being your only other option during multi-cam editing.
    You get this by holding down the Ctrl as key as you switch shots.
    Once you’re done, you can replace the dissolve by dropping a different transition on top of it.
    Hope this helps.
  • John Perez
    September 7, 2009 at 7:34 pm
    That did it! Thanks so much, Mike…
  • Norman Willis
    September 11, 2009 at 3:07 pm
    Hi Mike.
    Are cuts and dissolves the only options in Ultimate S?
    Thanks.
    Norman Willis
    http://www.nazareneisrael.org
  • Mike Kujbida
    September 11, 2009 at 3:19 pm
    Sorry Norman but I use Excalibur.
    I’m sure John Rofrano will answer your question very soon.
