Activity › Forums › Adobe Premiere Pro › Can’t see text when renaming items in the Project Window
  • Can’t see text when renaming items in the Project Window
    Posted by Matthew Woods on January 10, 2018 at 2:27 pm
    I Just upgraded to the latest Premiere, and now whenever I try to rename an item in the project window, I cannot see the highlighted text that I am renaming. If I type blindly and press return, it renames the text and I can see the text again, so I guess its a minor annoyance but I don’t see any one else on the cow complaining about it.
    Anyone else have this problem?
    -Matt
    Check out my plugins for AE, Premiere, Motion and FCP.
    https://monadnock.org/plugins/
    Matthew Woods replied 8 years, 8 months ago 1 Member · 1 Reply
  • Matthew Woods
    January 12, 2018 at 4:30 pm
    If by remedial steps you mean quitting and relaunching. Restarting. I tried those and they didn’t work.
    I then discovered that I somehow had two projects windows open in the project in question.
    One worked as normal, the other misbehaved.
    I closed the misbehaving one, and the problem has not recurred.
