Activity Forums Adobe After Effects Can’t see R3D files after latest update and RED plugin
  • Can’t see R3D files after latest update and RED plugin
    Posted by David Henion on December 23, 2008 at 3:44 am
    I installed the Red CS4 installer from red.com/support and the additional RED edit settings plugin, but when I go to import I still cannot select R3D files as a valid footage file – it won’t even display R3D files in the file import window.
    I did install the red plugin BEFORE installing the AE 9.0.1 patch, so following a post I saw somewhere, I removed the red installer and re-installed it. Still no go.
    I’m on Windows XP 64bit, dual-quad core w/ 8G RAM.
    I tried loading one of the .mov proxy files, get an error that it can’t find the “” file – so I tried doing ‘search’ and selecting the R3D file there. It kinda brings in a clip at the right size, but its completely white.
    What am I missing? Latest AE and RED plugin – but can’t load R3D files…?? Help!
    Many thanks for any ideas
    David Henion
    http://www.RadiantVFX.com
    Kelsey Shanahan replied 17 years, 2 months ago 2 Members · 1 Reply
  • Kelsey Shanahan
    June 16, 2009 at 5:46 am
    Minimum system requirements states Vista 64 SP1 or greater… could this have anything to do with it?
