Activity Forums Adobe Premiere Pro Can’t see “IN/OUT” in any Transition-Dissolve?
  • Can’t see “IN/OUT” in any Transition-Dissolve?
    Posted by Michele Poggi on April 23, 2017 at 7:03 pm
    I started using Premiere CC 2017 these days, and I’ve found a really strange absence in it, it MUST be an option somewhere.
    When I did simple dissolvences like che cross/additive ones in previous instances, I could see in the record monitor the in/out sources dynamically changing, to perfectly match the desidered result.
    …In this version it doesn’t happen. I tried different things, without success.
    It does show them if I MOVE the transition, but not if I expand or “compress” it.
    Any idea? Help? Thank you very much, as always guys.
    Michele Poggi replied 9 years, 4 months ago 2 Members · 3 Replies
  • Michele Poggi
    April 26, 2017 at 10:57 pm
    Bumping, maybe I’ve been unclear.
    I mean:
    When I added a transition, in the past while deciding how long it to be Premiere SHOWED the in/out of both clips chaning dynamically, to actually trim the transition. In CC2017 it seems to… Not do that.
    Is there a reason?
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
  • Peter Garaway
    April 27, 2017 at 10:19 pm
    hi Michele,
    In order to see the in and out points of your trim, you will need to disable ‘Composite Preview During Trim’. It is enabled by default. You can do this by accessing the tools menu (wrench icon) in your timeline.
    I’m not 100% if that was always the case. I’ll look into it!
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Michele Poggi
    May 1, 2017 at 12:23 pm
    That’s exactly what I was searching for-!
    I wonder.. What does that option do anyway?
    I need to go more in-depth with this.
    p.s.: anyone here has cc2017 paralyzing itself on quit with the droverlord tab opening?
    Editor Video
    Graphic Designer
    Digital Compositor
