Activity Forums Adobe Premiere Pro Cant see image when dropped in timeline (CS6 with latest updates)
  • Cant see image when dropped in timeline (CS6 with latest updates)
    Posted by Danny Winn on July 27, 2013 at 7:06 pm
    So I’m using Premiere Pro 6 with the latest updates and when I drop and image or clip into the timeline I can’t see the image in the program sequence window until I render it which is obviously a big problem.
    Any ideas on how to fix this?
    PS: I had this problem before the updates too.
    Tim Kline replied 13 years ago 4 Members · 3 Replies
  • Todd Perchert
    July 29, 2013 at 10:40 pm
    When you say ‘render’, do you mean a preview render on the timeline or a movie export?
    And let’s start simple…
    Drag a clip to the new item icon (lower-right corner of the bin) and make a matching sequence.
    Go to ‘Window’ file menu select ‘Workspace’ drop down and select ‘editing’
    Then go to the same ‘Window’ file menu/’Workspace’ and select ‘Reset Current Workspace’
    Now do you see any timeline image?
    TC
  • Michael Scarn
    August 8, 2013 at 6:10 pm
    Just to make sure, are you positive the track output (eyeball on the track) is toggled to on?
    Silly, I know, but it’s one of those random things one can forget.
  • Tim Kline
    August 19, 2013 at 8:39 pm
    Can you send me a Screen Shot of this. I will see if I can trouble shoot it or send you a tutorial on how to fix it.
    Tim
    https://www.fourtendigital.com
    tim@fourtendigital.com
