Activity Forums Blackmagic Design Cant see decklink motion jpg files in PPRO 2.0 And AFTER EFFETS 7.0 on secondary PC
  • Cant see decklink motion jpg files in PPRO 2.0 And AFTER EFFETS 7.0 on secondary PC
    Posted by Oliver Petz on October 2, 2006 at 5:34 pm
    Hi everbody
    on my secondary PC Decklink Software codes are installed, and any programm ( Windows-Mediaplayer, Zoomplayer etc) can play the motion-JPG-files which are capturd with Decklink Extreme on my first PC. But if i import the files to PPRO 2.0 or AFTER EFFECTS 7.0 ( Production Bundle , all updates are installed…)the screen is black,
    you see nothing while playback the files
    Sorry for horrible english
    Oli
    Oliver Petz replied 19 years, 11 months ago 2 Members · 2 Replies
  • Oscar G.
    October 2, 2006 at 11:53 pm
    hy
    While waiting stand alone codecs for secondary pc…
    Install drivers of decklink on this pc. It will add the codecs (and all the deckink software, even if a part need the hardware…)
    Do a system restore point and uninstall standalone codec 4.9 before.
    If you experience troubles with Ae and ppro juste uninstall the driver.
    Best regards
    Oscar
  • Oliver Petz
    October 6, 2006 at 9:11 am
    Hi Oscar,
    Thanks for your help
    After uninstalling BMD Software codec and installing the BMD Driver 5.71 on my secondery PC without BMD-Hardware all motion-JPG-files are visible in PPRO and AE but After effects crashes while rendering a projekt which contains BMD-motion jpg files. If i exchange the motion JPGs Files
    with ” normal” DV Files caputerd with BMD DV Compressor, After Effects works fine ( same project)
