Activity › Forums › Avid Media Composer › Can’t see clip with effect or title when in pause
  • Can’t see clip with effect or title when in pause
    Posted by Phil Byrd on February 12, 2013 at 3:32 pm
    Recently updated to MC 6.5.
    Problem is that when the timeline is paused, a clip with an effect can’t be seen in the record viewer. However, it can be seen on the client monitor if the playback was stopped with the space bar. But if stopped with the startstop button under the record monitor, the effect is not seen on the client monitor.
    This also applies to titles on the sequence. And a title created with Title Tool is invisible in the source viewer unless it is in play. When stopped, title goes away.
    I’m using Blackmagic Designs DeckLink Studio 2 for I/O.
    Is there a setting I’ve overlooked?
    Thanks all.
    Michael Phillips replied 13 years, 7 months ago 2 Members · 1 Reply
  • Michael Phillips
    February 12, 2013 at 3:59 pm
    I am seeing the same thing in software only, even with the correct render setting for pause (not in front of a system right now for the correct menu setting).
    Michael
