Activity Forums Adobe Premiere Pro Can’t See Audio Track
  • Jon Barrie
    August 9, 2011 at 4:03 am
    What is likely happening is the audio from the clip is in say mono with a L and R channel separated. The 1st 3 audio tracks by default are stereo which can only accept stereo audio clips.
    So the Mono clips (or 5.1 clips) get added underneath to their own Mono (or 5.1) track to match the clip type.
    Use the mouse to move down the tracks and you will see the audio.
    To clean up the empty tracks you can right click where the track names are and select delete tracks… then tick delete and select all empty.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Todd Kopriva
    August 9, 2011 at 6:29 am
    Here’s a video that demonstrates what Jon said:
    https://www.video2brain.com/en/videos-4009.htm
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
