Activity › Forums › Adobe After Effects › Can’t see anything in viewer window. Just black!
Posted by Dale Cullis on July 30, 2012 at 9:48 amI know this has been asked before, but none of those solutions seem to work. I am completely new to after effects, I know I must just have a setting wrong somewhere but I can’t figure it out and i’ve looked online a lot.
I import and image to a new project, then put it in a new composition, but I can’t see anything.
Caps lock is off, wireframe is unchecked, and I have reinstalled.
I’d really appreciate any advice 🙂 Thanks
P.S. Even if I make the composition background like bright green, and add nothing to it, the background still won’t show in that viewer
Jessica Poutous replied 13 years, 8 months ago 5 Members · 19 Replies -
Walter Soyka
July 30, 2012 at 1:47 pmAre you looking at a comp viewer for that composition, or perhaps a layer viewer, footage viewer, or locked comp viewer?
A screenshot showing your full UI will help us diagnose your problem.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Dale Cullis
July 30, 2012 at 2:15 pmHi Walter, I’m sorry, I just attached the screenshot but not sure it has come, just in case: https://f1.creativecow.net/4454/my-current-window It is here 🙂 thankyou
Walter Soyka
July 30, 2012 at 4:19 pmNothing is jumping out at me — can you File > Collect Files, zip up AEP and the PNG and post the whole project?
Walter Soyka
Dale Cullis
July 30, 2012 at 4:52 pmhttps://f1.creativecow.net/4457/curtains-project-file?uploaded=file Here you are, thanks for helping, I am literally pulling hair out here!
Walter Soyka
July 30, 2012 at 5:13 pmLooks fine here. Must be something wacky going on…
I recommend you first reload the footage (right-click in the project panel, choose Reload Footage), and failing that, clear your caches with Edit > Purge > All Memory and Edit > Preferences > Media & Disk Cache > Empty Disk Cache.
Walter Soyka
Dale Cullis
July 30, 2012 at 10:59 pmNone of that worked. Really can’t see what’s wrong. When I purged all memory, the image flashed on the viewer for a second and then back to black.
Walter Soyka
July 31, 2012 at 2:12 pm[dale cullis] “When I purged all memory, the image flashed on the viewer for a second and then back to black.”
Well, that’s really strange. You purged the disk cache, too?
Can you see other PNG files? Can you see that specific image if you convert it to another format (PSD or TIF) first?
Walter Soyka
Kevin Reiner
July 31, 2012 at 3:34 pmTry this.
As Walter suggested, change the file to another image format. Then reset AE prefs. To restore default preference settings, hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting.
Then start a brand new project, new comp, and see if you still have the problem.
Hope you get it figured out,
ReinerMac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23″ flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
Dale Cullis
July 31, 2012 at 8:16 pmHi, yes I purged the cache, and i’ve tried it different formats. I reset the prefs, and then started a new project, and re-imported into a new comp, and still nothing shows up in the window?
I really can’t see why this is happening
I just tries importing .mov aswell just to see if it would work, and it is just a black screen for that aswell
Kevin Reiner
July 31, 2012 at 9:13 pmAre you able to see other image files? Does it appear that its a problem with just this image, or is there a systemic problem within AE of not seeing any images?
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
