Activity Forums Boris FX Can’t see any fonts listed in Font tab of Styles palette in Red 5
  • Can’t see any fonts listed in Font tab of Styles palette in Red 5
    Posted by Peter Honig on August 28, 2011 at 7:44 pm
    Hi all. I am currently running Red 5.0.6 on Vista 64. When I view the tabs in the Styles palette, all function correctly except the Font tab (where I see no fonts listed). However, the fonts are accessable from the drop-down list in the Text composition palette. This happens with both the 32 and 64 bit versions of Red in both stand-alone and Vegas plugin modes.
    Peter
    Peter Honig replied 15 years ago 3 Members · 4 Replies
  • Peter Mcauley
    August 29, 2011 at 1:41 pm
    Hi Peter,
    I think you can resolve this by creating a new style category. To do this, go to the Font tab in the Style Palette and then click on the Add Category button, which is just below the pop-up selector. Give it a name and click OK. All fonts on the system should then appear.
    I hope this helps.
    Peter.
  • Peter Honig
    August 31, 2011 at 12:26 am
    Hi Peter,
    Thanks for your response. I am currently traveling and will try your suggestion this weekend.
    Regards,
    Peter
  • Steve Pankow
    September 2, 2011 at 11:13 pm
    Has the font management changed any since ver. 3? I tend to break fonts down into separate categories (serif, san serif, etc.) but when I want to add new fonts, I’m forced to rebuild the entire category and then begin the tedious process of deleting the ones I don’t want to keep.
    RED being able to scan the OS font directory and comparing it against it only newly added fonts would be nice, thus not forcing a total rebuild each time.
  • Peter Honig
    September 3, 2011 at 12:51 am
    Thanks Peter. Your suggestion worked as described.
    Peter
