cant see animation in render, what’s going on
Hi guys I am new here.
I have made a rubik cube with animation. It was tricky but I did so following the instruction of this video (https://vimeo.com/115217915) with inheritance plus xpresso animation.
I can see all sides rotating as desired in viewer, all seems ok.
However, when I tried to export the animation as PNG sequence, I get some really weird result, I can see all sides of the cube changing colours as it reaches the right key frame, but I cant see any movement. I tried MP4 and AVI, all the same result.
Funny thing is, when I export it as a single frame in PNG or JPEG, I can see the animation result (in motion), but it just won’t work as a sequence. I checked the cube xpresso function and made sure it can be seen by render.
Do you have any idea what is causing this? Many thanks in advance.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
