Activity › Forums › VEGAS Pro › Can’t save Project Properties as I want them
  • Can’t save Project Properties as I want them
    Posted by Lord Porongus on December 20, 2016 at 11:19 pm
    Is there a reason why every time I start a new project this two options start as enabled?
    I always have to manually disable them.
    Lord Porongus replied 9 years, 9 months ago 2 Members · 2 Replies
  • George Dean
    December 21, 2016 at 12:38 am
    The only way I know of to save the lower part of the Project Settings, is to start a new project, set the project settings you want as default, then save that as something like ‘Default Project’ to your desktop. Then whenever you start a new project load Vegas by clicking on the ‘Default Project.veg’ desktop icon, or after loading Vegas, open the ‘Default Project.veg’, then immediately save this project with an appropriate name of your project in the your projects folder, so you do not inadvertently save over the ‘Default Project’.
    Maybe someone else knows a trick I don’t. If so I would also like to know.
    Best Regards…..George
  • Lord Porongus
    December 21, 2016 at 12:43 am
    Not a bad idea. I’m gonna use your way as a temporary solution. Thanks George!
