Activity Forums Adobe After Effects Expressions Cant return two values in a other layer
  • Cant return two values in a other layer
    Posted by Pascal Frei on November 3, 2020 at 7:57 am
    Hello there, i got trouble with my code, i have two diffrent comps with two text-layers. I will show those texts from this layers in a thirt layer.
    I got Headline1, Headline2 and the resultheadline. This code is add to the resultheadline:
    var a = thisComp.layer(“Headline2”).text.sourceText.getStyleAt(0,0);
    a = a.setText(footage(“myFile.json”).sourceData.productname);
    var b = thisComp.layer(“Headline1”).text.sourceText.getStyleAt(0,0);
    b = b.setText(footage(“myFile.json”).sourceData.headlineproduct);
    function myFunction(a, b){
    result = a + b ;
    return result;
    value = myFunction(a, b);
    I get no error message, AF is just show me [object Object][object Object]]
    How can i return the values from Headline1+2 in resultheadline?
    Thanks a lot for your help!
    Kind regards PF
    Brendon Murphy replied 5 years, 9 months ago 2 Members · 3 Replies
  • Brendon Murphy
    November 3, 2020 at 9:40 pm
    Try this in the resultheadline source text:
    var a = thisComp.layer("Headline1").text.sourceText;
    var b = thisComp.layer("Headline2").text.sourceText;
    a+", "+b;
  • Pascal Frei
    November 4, 2020 at 12:44 pm
    Hello Brandon,
    Thanks a lot for your reply. Yes sure in this case it works. But when you have a closer look at the code i have written you can see I need also the stylized information propperties. And thats the reason i think why i get this error [object Object][object Object]] AF cant handle this..
    mabey now you know what I mean.. Thanks for your support
  • Brendon Murphy
    November 4, 2020 at 9:29 pm
    Gotcha. I’m not sure if you can combine two separate text styles on one layer using expressions. Let’s see if anyone else has seen this.
